Starting issues with F-350 6.0 Diesel
I have a 2006 Ford F-350 6.0 Diesel Engine Truck. I am having real problems starting the engine after turning off the truck after it is warmed up. If I wait a couple hours it will start fine however. The battery is fully charged and cranking fine. The engine just doesn’t turn over.
I am able to work around the problem when I wait for a faint sound (which I think is the fuel pump possibly??) to stop. It is a quiet humming sound. Once that stops the engine will start no problem. I usually have to wait about 10-12 seconds for that sound to stop after turning the key to the ready position before I try to start the truck.
I have the check engine light on and the check engine codes that are thrown are:
P2286 - Injetor Control Pressure Sensor High
P2289 - Inector Control Pressure To High
Any ideas?
Thanks so much!
Any ideas?
Thanks so much!
Thanks so much.
Rob
Ford Girl
01-11-2010 10:28 AM
