Stubborn steering bolt on '89 F250
Old 04-13-2009, 06:23 PM
atowinram's Avatar
Default Stubborn steering bolt on '89 F250
I am replacing the steering column in my husband's farm truck...an '89 F250, 351, 4x4, automatic. I have one stubborn bolt that is keeping me from getting the column out. It is the bolt that goes through the coupler to join the end of the column with the top of the steering shaft.
Here's a couple pics:
I have tried penetrating oil, a propane torch, and different size rachets, but I can't get it to move. The head end is flat to the coupler, and the threaded end just comes out through a forged lip on the other side. I don't see any splines or locking rings that might be holding it up. Any ideas what to do next?
Thanks!
Old 05-08-2009, 02:00 PM
david paul's Avatar
If i'm not mistaken that bolt is splined and you will have to use a brass drift punch to knock it out a check when you get it out as it may only go in one way hope this helps
Doverust
08-14-2012 12:30 AM
80ford302
10-01-2011 08:42 PM
97F250fan
10-20-2010 05:13 PM
POLiSH
09-17-2007 10:10 PM
Kurtech
02-13-2007 02:08 AM
Quick Reply: Stubborn steering bolt on '89 F250
