Tire Question
Tire Question
Ok I have an 05 f-250 6.0 with 275/70R18's... It came that way,,, Now I have found a smoking deal on a set of 17s I know it is 1 inch but what is going to be my big Pro's and Cons With these new tires?
Any Help would be greatly appreciated
Thanks
Fordman
Thanks
Fordman
18" is your wheel size, 17" tires won't physically fit on your wheels. You would have to buy new wheels as well.
The 275 in your tire size means the nominal width of the tire in mm (11" approx.)
The 70 is the ratio of sidewall to width (70% if 275mm = 193mm/7.6")
Your outside diameter is 2x7.6" + 18" (wheel/rim size) = 33" approx.
18" tire selection is somewhat limited and are more expensive then most sizes, but some 17" wheels might not even fit over your breaks (I know most won't in my 08).
