trailer brake controller
Old 07-19-2006, 07:57 PM
scott's Avatar
Default trailer brake controller
Havine hard time hooking up brake controller on a 2001 f-250,cant find blue wire under dash. Where are the wires located for controller.
Old 07-22-2006, 01:21 PM
Default RE: trailer brake controller
You 'should' have a controller adapter cable that was in the glove box packet when new.. If not, they can be had from Ford.. If you remove the lower access panel below the steering column, the controller cable plugs in 'up high' in the 'right upper' corner towards the radio/heater controls (grouped connectors) forward of the dash bracket (steel)..You'll see some grounds attached as well..The cable plugs there..
......................HP......................
Old 07-25-2006, 12:32 AM
scott's Avatar
Thanks for the info
Mouse6196
07-01-2014 12:55 PM
93f250xlt4x4
07-03-2008 10:02 AM
iamb4u
09-14-2007 03:35 AM
dee004
04-02-2007 08:26 PM
floyd
08-11-2006 01:29 AM
Quick Reply: trailer brake controller
