Montego Speedo in a Five Hundred help
Old 10-21-2014, 06:14 PM
Five*Hundred's Avatar
Default Montego Speedo in a Five Hundred help
Hello everyone, hopefully someone can help me with this.
Recently my wife and I decided to get a new vehicle due to my daughters arrival, the Prius is now to small for our family.
So she also mentioned that I should also get a new vehicle because I deserved it. Now my FH has never let me down but is was as blend as it gets inside due to the fact that I had a base model.
So in order to just have 1 car note instead of two, I decided to upgrade the interior myself.
1. Dark Montego interior trim with center clock (needs to be connected) 98% done, need the door handles to match
2. Upgraded MP3 OEM radio with Sync (needs a few things to button it up, to be able to fully use the Sync option)
3. Rear passenger vents/power outlet on rear of center console
4. Chrome Montego rings on the speedo
And now to my problem, since i have a base model I wanted a few bells and whistles as you can see, so I purchased a Montego speedo with the message center. I plugged it in and speed and rpms work, warning lights work, BUT here is the problem, I am due for an oil change (my current speedo tells me that) and so the the Montego one, but I can't get out of that message on the Montego speedo, ALSO i have the TC warning light on the top left corner staying on (you know...the one that flashes when you skid).
Can anyone help me on how to resolve that? Should I get a Montego ECU and use it on conjunction with the Montego speedo? The stealership says to bring it in and leave it with them so they can sit with a schematic drawing and see if they're wired the same all that for $175.
Any suggestions?
Dredge
11-08-2009 11:14 PM
Tennesseestorm
03-23-2007 02:04 PM
Tennesseestorm
02-04-2007 04:39 PM
DCDave
12-01-2006 11:11 PM
gaypat
10-10-2005 12:35 AM
Quick Reply: Montego Speedo in a Five Hundred help
