05 Five Hundred Crank but no start sometime
My 05 five hundred crank but no start sometime. I have replaced fuel pump, fuel transfer pump, fuel pressure sensor, fuel filter. But still sometime happens. Does anyone have any idea or advice, please?
It , the driver module, should be located in the pass side of the trunk. One check you might check is if there is power to the module when everything is working, then check if that power is present when the problem surfaces.
In your vehicle owner's manual , in the "Specifications" section, are diagrams of what each fuse protects and locations of the various relays. There are usually 2 panels , one is usually located in the engine compartment (Power distribution) and one inside the vehicle. The relays are usually located in the engine compartment panel and some panel covers show which relay does what. Determine which one is the fuel pump relay and if and when you have the no start problem , temporarily swap the fuel pump relay with another relay for some non starting function.
Ok. Thank you for advise. Owners manual didn’t come with the car but I have located relay. I was not sure how and which prong to check with it. Sorry about that my comment may make you misunderstand what I tried to say. I will try it how you advise me when it happens again. Thank you
