Upper Motor Mount
Old 02-04-2017, 07:35 PM
idlehands9's Avatar
Default Upper Motor Mount
2005 Limited AWD. My upper motor mount rubber is fading away into bits and pieces. Is there a rubber bushing that can be installed WITHOUT pressing in into place? Any help is welcome.
Old 03-12-2017, 04:34 PM
Zeke's Buddy's Avatar
Default Just changed my upper mount.
Hello idlehands, I recently changed my upper mount. It was a little difficult to do to tell you the truth. I didn't do it this way, but somewhere online someone had a Volvo mount they placed inside the existing mount. If you have the right tools the easiest way to take the whole mount off is to take the intake manifold off, and it makes it very easy to remove the entire bracket from the transaxle. From there you can take the entire thing to a mechanic and have it pressed out. If you do remember to tell the mechanic to press it in the same way it came out. Well good luck, and if you need any suggestions let me know.
tennesseesaturn
04-22-2011 05:41 PM
two 50
11-04-2008 11:35 PM
rlevy64614
10-19-2008 08:20 PM
kerwinq
08-30-2008 10:46 AM
cooljman1
03-31-2008 12:01 AM
Quick Reply: Upper Motor Mount
