Ford Flex This new crossover offers the interior room of a minivan with the vintage design of a classic panel truck.
Flex overheated
Old 10-01-2014, 11:40 AM
Babulas's Avatar
Default Flex overheated
On her way back from work, my wife's Flex overheated and could not longer be driven. The temperature gauge went all the way to the red marker. Obviously, the engine light came on. There was enough coolant and oil. A tow truck drooped the Flex at a Ford dealership. Today they called me and said it needs a new engine ($7000 plus). Reason is that they found coolant in the oil and there has to be a crack in the engine block.
If that's the case, why there was coolant (the service rep originally said there was no coolant. I told him that was not the case and he quickly changed conversation). When I asked what caused the over heating, he said he does not know.
The whole thing smells funny. What else can I do to verify what's really going on?
2010 Flex.
Old 01-08-2015, 02:46 PM
NeverEnoughAuto's Avatar
Former Sponsor
maybe I should wait getting a Flex sounds like.
Old 01-10-2015, 12:06 PM
Lars(nowintexas)'s Avatar
There more than likely is coolant in the oil,now. Was there coolant in the oil before it overheated is the question?
I would be on the horn with Ford district headquarters and melting their phones till I got action on Ford's part. How old/milage of this vehicle? Warrenty?
Old 08-06-2015, 08:27 PM
chris_wisconsin's Avatar
I was very excited when we first bought this vehicle but if I knew then what I know now. NO WAY! 4 wheel bearings went bad before 80K, Fan controller bad at 95k radio bad at 80k. This is by far the WORST vehicle I have ever purchased! The dealer in my area, same thing. I had factory warranty to 100k but had to pay $100 every visit. took three visits to fix radio!! Shame on the engineer who put mounting screw for controller below plug where you cannot see it. This car, a top of the line 2009 Ford Flex is horrible. Did I mention that the Sun roof leaks? and NO there is no debris blocking the drain ports. Stay away! I have never written before on a forum but now I am an enthusiastic Ford Flex basher. JUNK ,JUNK, JUNK, Had a 2002 Honda minivan 289000 when tranny went. Back to Honda! I wanted to buy an American product! Shame on Ford. You knew these wheel bearings were not up to the task and you specked them anyway. Maybe you Should have taken the bailout money and spent it in engineering. NEVER AGAIN!
Old 08-06-2015, 08:41 PM
primem's Avatar
wheel bearings fail on Honda's too, except its 3 hours labour to install because they use retarded pressed in bearings. maybe I should blame the engineer?
Old 08-08-2015, 08:47 PM
primem's Avatar
Originally Posted by chris_wisconsin
NEVER AGAIN!
Don't pm me your grief.
this is a public form. if you post here you will get other opinions like it or not. buy what you want its your money. Why would I give a ****? if you have a comment for me put it on the public forum.
this is a repair forum. like most ranters; post your 1 rant, help no one and then leave.
Old 05-02-2016, 11:39 PM
Ferrofab's Avatar
Most likely your water pump failed. Do a search for 3.5 liter Ford engine water pump failures. I just purchased a 2010 Flex with identical condition. I'm putting a 24,000 mile Flex engine (from a 2011) in for under $2500. Sometimes the engine can be saved if the failure is detected immediately (I don't know how to do that myself - maybe temperature gauge).
Old 05-03-2016, 01:25 PM
Alanah_Rae's Avatar
Agreed with you !!
Greasy Creek
06-12-2012 02:47 PM
CoyoteRoede
11-04-2006 12:49 AM
nclay
05-15-2006 11:55 PM
2001platinum
05-05-2006 02:45 PM
Doug4.7
11-09-2005 09:59 PM
Quick Reply: Flex overheated
