heater fan not working
Old 09-18-2014, 02:04 PM
Harry Hubbard's Avatar
Default heater fan not working
the heater fan in my ford focus cmax 2006 1.6 tdci has stopped working...any ideas what it could be? its not a fuse as i have checked them all...thanks
Old 11-08-2014, 07:42 AM
brian6410's Avatar
check fan motor
Old 11-08-2014, 08:24 AM
A test lite or voltmeter would be helpful if one was available.
The check is to determine if power is getting to the blower motor when fan is requested.
If power is present there, confirm the ground connection is good. If that is OK the blower motor can be removed and checked for being free to move. If it is free to move and does not work with power and ground provided ,replace it.
If power is not available to the motor, tests need to be done starting from the fuse connection on to the blower control portion of the system. There could be a relay in the circuit. Do any of the speeds work?
reynard
12-06-2023 03:25 AM
bardo
04-17-2007 09:57 AM
chiroken
01-24-2006 11:39 PM
chiroken
01-22-2006 08:54 PM
krittrkeepr
01-14-2006 09:27 PM
Quick Reply: heater fan not working
