no heat
no heat
ok folks ....i have a 2001 ford focus with no to little heat. if you turn heat off for about 5 minutes and then turn back on you have warm air for about 2 minutes then it blows cold air again. the temp is running in the normal range and the fans are running ....the AC has never worked on this car since we bought it..i dont smell antifreeze in the car...any thoughts where to start first
thanks
thanks
