Rough Idle, number 2 cylinder misfire
Old 08-30-2006, 04:53 PM
miknwv's Avatar
Default Rough Idle, number 2 cylinder misfire
2000 Ford Focus 4 cylinder SE with the dual overhead cam..... sometimes has an intermittent rough idle throwing a C/E light.... hooked up to machine, says number 2 cylinder misfire. new plugs, new wires, still doing it. any ideas?
Old 08-30-2006, 05:50 PM
Default RE: Rough Idle, number 2 cylinder misfire
Check it for vacuum leak's.
Old 08-31-2006, 12:22 AM
The coil may be going bad causing the miss. Check it with a spark tester.
Old 09-03-2006, 04:16 AM
miknwv's Avatar
thanks guys, will check
mardyel
12-14-2016 11:21 AM
Sandman400
03-30-2013 12:46 PM
jeremychips
04-05-2012 06:41 PM
Tuolumnejim
05-27-2010 06:25 AM
miknwv
09-02-2006 03:04 PM
Quick Reply: Rough Idle, number 2 cylinder misfire
