Ford 500: Wiper Arms
I have a relatively easy problem. How does one take off wiper blade arms from a 2006 Ford 500? I have removed the nut okay, but I am unable to proceed. I need to figure out the source of water that fills the entire floor on the passenger side.
Don't know if you already removed the wiper arms or not, but... What I do is place the nut back on until it's flush with the stud. Then lift the wiper arm to it's up position. Then I take a pair of channel locks and put the jaws over the nut and under the wiper arm and squeeze. That should pop the arm loose from the stud.
Sean Neufell
06-28-2015 07:34 PM
ProStreetDriver
08-23-2013 11:15 PM
dragbike425
01-13-2009 04:38 PM
mdcar
04-29-2007 05:05 PM
