Need Help, brakes on grinding can't figure it out
Old 09-29-2015, 06:26 PM
pete1933's Avatar
Default Need Help, brakes on grinding can't figure it out
hello everyone,
I am new to this thread and need some help. I have a 1933 Ford street rod with a Mustang front end with disk brakes and the rear end comes out of a 1978 Lincoln Versailles that is also disk brakes. The problem I am having is the car's brakes will grind going in reverse but the grind does not happen in forward or neutral. I have check everything and this one has me stumped. Any help with this would be appreciated before I have to take it in. If you need any other information that would help to diagnose this please let me know.
Old 09-29-2015, 11:14 PM
Thumbs up
Welcome to the site...
Any change when the brakes are cold/heated?
Old 09-30-2015, 08:24 AM
primem's Avatar
what does grind mean.....they apply in reverse or just make noise? Have you removed and inspected the pads? Are the backing plates contacting the rotors. This will make a tinny scraping noise.
Did this just start happening, indicating the system worked properly at one time. Was the system always like that since you bought the car?
What else was changed in the system....metering, proportion valves.?? You now have a vacuum booster on it? These parts were from the 78?
Old 10-02-2015, 12:53 PM
pete1933's Avatar
it dose it worse in the morning, but dose it off & on thru the day.
pete
Old 10-02-2015, 01:00 PM
pete1933's Avatar
nothing was changed in the system.
it has done it since we bought it. pads, rotors look good, car brakes good while driving.
thanks for help
pete
Old 10-08-2015, 11:29 AM
Skyhawk's Avatar
Are the disk pads installed correctly? Unusual question, but I have seen the metal side of the pads installed against the disk.
bombie1138
06-04-2015 06:50 AM
Joelb58
06-07-2013 05:20 PM
jasen
02-18-2012 04:31 PM
theonlykb
02-13-2012 07:58 AM
zr800
03-13-2008 10:30 PM
Quick Reply: Need Help, brakes on grinding can't figure it out
