Rear end I'd tags f150 - Ford Forum - Enthusiast Forums for Ford Owners
Thread Tools Search this Thread
Old 03-15-2017, 09:07 AM
Default Rear end I'd tags f150
I am missing Id tags on f150 differential how else can I determine the correct rear end
Old 03-15-2017, 01:56 PM
Thumbs up
Welcome to the site.
What year 150? If it's a later build 150, the certification label in the drivers door jamb would have the axle code (if nothing has been changed out)
If correct ratio is in question, another way to figure for ratio w/no tag, is to raise the axle and mark the axle flange location,, rotate the input yoke and count complete turns and partial (clocked) to make the axle rotate a full revolution to your mark.. Depending on MY, axle/gearsets would be a guess...
Thread Thread Starter Forum Replies Last Post
leak from rear end....possibly rear diff? escaped-eric Ford Escape 3 12-23-2012 01:33 PM
2006 f150 rear end clunking titletown Ford F-150 5 10-07-2012 10:20 AM
Temporary fix F150 rear end, will it work? Richard7425 General Tech 10 02-27-2012 09:33 PM
99 F150 super cab, feels like slack in rear end when changing into Over drive? wvpackman Ford F-150 0 06-08-2010 10:36 AM
Rear end and rear drive shaft f-250 CaptJack101 Ford F-250 & Ford F-350 2 03-12-2008 12:30 AM
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
