Heather not heating
Old 10-30-2018, 09:08 PM
Christian Butter Poulin's Avatar
Default Heather not heating
Hi.
Ford freestar 2004. 150000 miles
My heater doesn't heat. If I set the heat to max, it will just be less cold. Once on the highway, the heat will go up to "kinda warm". Coolant level is fine and there is no smell.
Any idea what's wrong?
Thanks
Old 10-31-2018, 09:39 AM
Default P.S.
Originally Posted by Christian Butter Poulin
Hi.
Thanks
Samething for rear heating
Old 11-02-2018, 12:48 PM
FCguy's Avatar
Well I was going to suggest that the climate control mixing valve was dead but if it's both then I'd guess that the heater core has a valve to either allow coolant to pass through the heater core or bypass it. Either that or the heater core is clogged with debris of some kind
Old 11-02-2018, 01:18 PM
What if we looked at it this way,
After running the engine for about 10 minutes, go and feel the two heater hoses under the hood.
If both are cool or slightly warm there is a good possibility the thermostat is in the stuck open position and removal would confirm this and replacement is required.
If one hose is pretty warm and the other is cold, there is a good possibility there is a restriction in the heater core .
If both hoses are hot there is a good possibility the blend door is stuck not allowing the air to get warmed up and be directed to the inside of the vehicle.
One last thing, depending on where you park the vehicle like, under the trees lot, debris can get into the area inside the heater box and block heated air from getting into the vehicle.
Not sure if your vehicle has a cabin air filter, but if it has never been replaced , good thing to do right before winter.
The thermostat is the first thing I would check.
Old 11-09-2018, 02:17 PM
One hot hose, one cold hose. Having the system flushed and changer the Filter. Should solve the problem. Thanks
tattooed_drew
04-06-2020 10:59 AM
paulv718
01-18-2017 09:23 PM
degar1877
01-02-2014 07:00 PM
jchittick34
11-12-2011 06:09 AM
gigs16
03-26-2007 01:53 PM
Quick Reply: Heather not heating
