2005 freestar loose steering wheel.
There could be several reasons for this among which could be worn outer tie rod ends, worn inner tie rod ends, worn parts in the steering rack and pinion syst, worn ball joints,wheel bearings and parts from the steering wheel connected to the steering assy.
As you can gather , the best thing you could do is to have the vehicle checked ASAP because this is a safety issue, not only yours, but others on the road with you.
If you are not happy with one estimate, get another ! It's not good to wait with these things because they only get worse. It could be only one of the above mentioned and maybe not expensive to correct, but driving it like that is not good.
rebar
05-12-2013 04:11 PM
ac917x
05-07-2012 07:44 PM
