2005 new alternator new problems
Old 11-08-2015, 12:22 PM
Frank777's Avatar
Default 2005 new alternator new problems
Just replaced alternator in a 4.2L Freestar and now the speedometer is out and he power sliding doors aren't responding. Also the trac off, ABS and Parking brake instrument lights remain on during driving. The code checks are P1502 and P2006. Could a control module failed during jump charge? Any advice? Thanks in advance.
Old 11-09-2015, 04:16 AM
Use Common Sense's Avatar
Did you reconnect this ground lead to the front alternator bolt?
Attached Thumbnails 2005 new alternator new problems-img_20151109_050738165.jpg
Old 11-09-2015, 12:12 PM
Frank777's Avatar
Yes all leads were reconnected. All fuses intact also. Still have same issues.
Old 11-10-2015, 03:32 AM
You might try a forced reset. Remove negative cable from the battery post, hold the end against the positive cable terminal for approx 30 sec then reconnect it to the negative battery post and see if helped.
Old 11-10-2015, 04:54 PM
Frank777's Avatar
Tried forced reset, nothing changed. Thanks for responding.
Old 12-19-2020, 06:08 PM
wboone11's Avatar
Exact same problem. Tried same things if you solve it please let me know how.
guthrie1013@gmail.com
06-25-2020 11:45 AM
bluzzer
12-13-2018 08:56 AM
goiou
05-16-2009 10:40 AM
tar40_40
11-30-2006 04:17 PM
oldschool1
North East
47
01-13-2006 04:25 AM
Quick Reply: 2005 new alternator new problems
