Cruise Control - Ford Forum - Enthusiast Forums for Ford Owners
Thread Tools Search this Thread
Old 07-08-2007, 09:21 AM
Default Cruise Control
Just had my tranny replaced on my 04 Freestar and now the cruise control no longer works. Dealership states the tranny change should not have effected the cruise control and I have a totally different issue. All fuses are good. Any other suggestions where to look. Need fix because I am traveling on vacation and driving without cruise control is a bummer.
Old 07-08-2007, 10:02 AM
Default RE: Cruise Control
Not sure what your problem is but I can remember a case where the transmission was replaced on a GM product and they forgot to connect a sensor on the transmissionn case. In that case the speedometer did not work neither so I would check with the people that replaced the transmission and have them check all the connections.
Make sure that they replaced it with the proper transmission also you could check with a Ford dealer and ask them where the cruise sensor is located.
Hope you get it fixed.
Thread Thread Starter Forum Replies Last Post
Cruise Control Brake sensor switch fires CaptJack101 Ford F-250 & Ford F-350 2 06-25-2009 06:35 PM
Cruise Control (AKA Speed Control) Fuse AP Ford Contour 0 07-28-2007 04:01 PM
Replacing Cruise Control Modules on 97 Explorer Steering Wheel audioguy Ford Explorer 2 11-22-2005 12:56 AM
92 F-350 Cruise Control bluecommando Ford F-250 & Ford F-350 3 09-23-2005 06:51 PM
Cruise Control '05 Spt Trc. Will 2003 Kit fit My '05? RHenry Ford Explorer 0 07-13-2005 02:11 PM
Tags
04, 2007, control, cruis, cruise, driving, ford, freestar, issues, problems
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
