help !!!!
help !!!!
Good day !!! My name is Dimas, I own a 2005 freestar, and this is the problem I'm facing, it starts with a fault that looks as worn spark plugs (107000 miles), we changed together with the cables, the fault continues; then we changed the coilpak nothing happens, the compression was check and it was ok, we removed the computer and test it outside and it was ok, meanwhile we test the van with another comp. and the problem persist. Because the code shows a problem with the cylinder 2 we start checking the cables that goes from the comp to that cylinder, then we found an injector cable corroded so we figure out that was the problem so we changed the harness. Guess what ?? The fault stills !!!
Please, someone have a suggestion, solution, etc. HELP !!!!
Thanks
dimasp28
Thanks
dimasp28
