Instrument panel
Instrument panel
The odometer was not working so I pulled out the instrument panel and touched up all the solder joints on the odometer module. Now the odometer works but nothing else does. All the fuses are good. Is there something that needs to be reset? Does it require a scanner? It is a 2005 Freestar with the 3.9 engine
the abs problem sounds like it could be a problem with the brakes. Are the abs brakes working OK?
