Instrument panel
Old 12-05-2016, 09:29 AM
tedbarrett's Avatar
Default Instrument panel
The odometer was not working so I pulled out the instrument panel and touched up all the solder joints on the odometer module. Now the odometer works but nothing else does. All the fuses are good. Is there something that needs to be reset? Does it require a scanner? It is a 2005 Freestar with the 3.9 engine
Old 11-18-2017, 03:02 PM
Littlehawk's Avatar
Hey, Did you ever get it solved? I have a code U1059 that the ABS circuit is not communicating with the instrument cluster. Any ideas what specific problem that could be?
Old 11-19-2017, 12:06 PM
tedbarrett's Avatar
I fixed it by changing the instrument panel with one I got from a local junkyard. It didn't cost much.
the abs problem sounds like it could be a problem with the brakes. Are the abs brakes working OK?
JdoubleU21
05-12-2007 09:30 PM
razorbacker
11-30-2006 12:17 AM
triley301
09-03-2006 07:47 PM
major99
01-28-2006 09:27 PM
sparhawk12345
04-09-2005 05:22 PM
Quick Reply: Instrument panel
