rear brakes 2004 freestar
Old 04-21-2006, 09:44 AM
Chem's Avatar
Default rear brakes 2004 freestar
I am in the process of changing the rear brakes on my freestar. I am having difficult time pushing the “piston” back. Looking at the brake mechanism it looks to me that the emergency brake bracket may be the hindrance. Any suggestions or comments out there?
Thanks for the help
Old 04-28-2006, 12:08 AM
Default RE: rear brakes 2004 freestar
I had the same problem. I know it seems crazy but all you have to do is push on it really hard while you are turning it. I braced the caliper up against the rotor and had somebody else hold it while I put all I had into it. Good Luck!
Old 05-02-2006, 07:19 PM
jcasaccio's Avatar
Can't you just use a c-clamp to push it in, like any other brake job? Let me know....
Old 06-11-2006, 11:10 AM
Yesterday I had this same issue and luckily I found your post. Yes, a heavy duty C-clamp and a lot more force than I would have expected did force the pistons back into the caliper bores. Thanks for your post: I'm not sure what I'd have done if I hadn't read it.
2005 Freestar SEL 33K
Old 07-07-2006, 04:06 PM
The piston has to be "turned" in clockwise while applying inward force! There is a freakin' tool for that to make life easier.
Old 07-29-2012, 12:41 PM
Skioutty's Avatar
I used 4 hands. LOL. A buddy kept light pressure on a C clamp while I rotated the pressure plate of the piston. Easy really.
2004freestarmatt
10-31-2022 08:55 AM
bdw43812
10-06-2013 07:33 AM
Weaver1959
03-18-2013 07:01 PM
freestar man
11-28-2010 03:49 PM
Boyd
12-27-2006 04:05 PM
Quick Reply: rear brakes 2004 freestar
