Rear Wiper Motor Loose
Old 12-09-2012, 10:06 PM
BlackSton3's Avatar
Default Rear Wiper Motor Loose
On my '06 I have noticed the rear wiper motor assembly seems to have loosened from it's mount inside the rear hatch.
Does anyone have R/R instructions for the inside plastic panel of the rear hatch? I'm sure I can probably figure out how to tighten the motor assy once I get in there.
Old 12-10-2012, 07:53 AM
Use Common Sense's Avatar
Remove the 2 bolts holding the PULL-DOWN handle on, remove the 2 philips screws (1 on each side of the panel) and then slowly go around the outer edge to pop the spring tabs out of their locations. You may have a couple of the spring locks slip off of their plastic tabs. Just remove them and put them back onto the plastic tabs before re-installing the panel. Install in the reverse order.
Old 12-10-2012, 09:39 PM
BlackSton3's Avatar
Great - thanks!
rebar
05-12-2013 04:11 PM
unionjackbell
03-04-2013 07:14 PM
redbear
03-22-2012 04:17 AM
jeffimac
11-15-2011 11:45 AM
fl_hayseed
03-30-2009 09:49 PM
Quick Reply: Rear Wiper Motor Loose
