van engine suddenly turned off
Old 08-16-2016, 08:31 PM
Rahoul Vicky's Avatar
Default van engine suddenly turned off
my vehicle is Ford Frestar 2005 sport van.
Actually today's while driving, suddenly my van engine turned off, I got almost an accident I was kind shocked because it never happen before.
Today after job i start the van and drive about five minutes I was in city around 40 km and suddenly the engine light appear, the starring jam and brake pedal was so so hard i was not able to push it, and the engine turned Off, all theses things happened in five secondes.
What it can be?
Old 08-17-2016, 03:59 AM
Use Common Sense's Avatar
HARD brake sounds like a brake booster problem. Check engine light and engine shutting down in conjunction with the hard brake sounds like a vacuum issue between the booster and the engine. I would start with pulling for codes, then check the vacuum line between the booster and the engine. The hose may be bad or came off some how, or the brake booster has failed.
Old 08-17-2016, 12:40 PM
i just check with OBD ll reader and it show no error at all.
i use this reader OBD ii wifi: http://www.x431update.com/photo/x431...5958_73084.JPG
and the app in my iPhone is: EOBD-Facile
is there a better app than this one or other way to find the problem by myself?
thanks
Old 08-18-2016, 03:38 AM
It is possible that no code was generated. The CEL coming on could have been just associated with the engine turning off. I would start looking at the vacuum line between the brake booster and the engine. You may need to remove the upper and lower cowling to get to it as it's buried back underneath the cowling. If your plugs and wires haven't been replaced in quite some time, now would be a good time to do it if you remove the cowling.
Old 08-04-2017, 03:05 PM
TTEUVKY's Avatar
The problem was Air Flow Sensor, it was dirty so i bought sesor cleaner for a few bucks and clean it, it has been now 1 years and it did never happend again.
this was for someone who have the same problem.
tauruspeeder
07-18-2013 09:50 AM
xxtank88xx
12-17-2011 09:38 PM
Theresatom
07-29-2010 07:38 AM
crisace
08-18-2008 10:17 PM
mccall33
10-04-2005 04:43 PM
Quick Reply: van engine suddenly turned off
