Water leaking in hatch area
Old 04-01-2017, 02:40 PM
soopacee's Avatar
Default Water leaking in hatch area
Another good ole 04 Freestar issue......I've had this problem for awhile now. Doesn't effect driving so I have been putting it off....long story short
The rear hatch area, after a good rain, floods out...like filled, big puddle etc......car can be parked whole time, still does it.......the lock for the rear hatch is broke and completely rusted out, I gave up hope on that........the only area i see water entering is on top of hatch, seems to be a little space, or around the license plate housing assembly area, seems to be a little loose on one side......water does settle down by hatch/lock
Any ideas what to use/do to seal it up.....how do I remove housing around plate?...just clips?...any info appreciated
If anyone would like to see pics, I can gladly take some to make it easier
Thanx
Corey
Old 04-07-2017, 08:51 AM
DougOfWar's Avatar
Default D
Thanx
Corey
I have exactly the same problem with my 2004 Freestar. My license plate housing pulls out a little on the right (when facing the rear of the van). My Freestar has the factory spoiler. Corey, does yours? I would also love to receive any info on how to resolve this problem. I'm ready to give her the caulk if someone will tell me where!
Thanks in advance for any help you can provide.
Doug
Old 04-07-2017, 01:24 PM
DougOfWar's Avatar
Doug
A little more info. It doesn't always leak inside the van but whenever we have heavy rain, the liftgate fills with water. Then when I open it I can hear water gurgling. Then when I close it water pours out of the drain holes. I think I'm going to try caulking around the license plate insert...
Old 04-08-2017, 08:42 AM
soopacee's Avatar
Hey Doug
No, mine has no spoiler.......same with mine, water settles around where it hatches, it's always wet there after rain
Do you know if the housing around license plate is removable?
Thanx
Corey
Old 04-08-2017, 12:22 PM
DougOfWar's Avatar
Hey Doug
Thanx
Corey
Yes, it is removable. You have to take the inner trim panel off of the tailgate. Remove the two Phillips head screws and the two bolts holding the handle on. Then just pull down on the panel. There are a bunch of clips holding it on. Then there are 7 nuts and two clips holding the license plate insert in. The five smaller nuts are rusty and one of the studs was already broken and three more of them broke during the removal. The studs are molded with plastic into the back of the insert. A terrible design. The weather stripping on the back is badly degraded and I think that this combined with the broken stud is where the water was getting in. I am going to remove all of the weather stripping and then run a very thick bead of construction adhesive in it's place. You will have access to your rusted latch mechanism. Maybe spray it all with rust penetrant and wait a day. Then hopefully your studs won't break off. But I'm sure that at least one of yours is already broken and that's why it pulls out a little on one side. I'll let you know if it passes the garden hose test after I get it back together and the glue has a day to dry.
Cheers and good luck,
Doug
Old 04-09-2017, 07:15 AM
soopacee's Avatar
Doug
Thank you for the info....I think I am gonna tinker with it next weekend
Please keep me updated with your results.....hopefully we can nip this in the butt
Thanx
Corey
Old 04-11-2017, 11:53 AM
DougOfWar's Avatar
Thanx
Corey
Well that was definitely where the water was coming in. It poured rain all night and this morning the rug was dry and there was no water in the tailgate. I'm positive that that's where your leak is Corey. If the fix works for you please post a message here.
Good luck,
Doug
Old 04-28-2017, 06:58 AM
soopacee's Avatar
Good luck,
Doug
That's great to hear!....I have been busy, but I am gonna do it today. I had off work last night so I have all day today.....and, they are calling for rain tomorrow.......will post with updates
Old 05-03-2017, 06:46 AM
soopacee's Avatar
UPDATE*****FIX
I removed the panel inside the hatch, you could see where water came in around license plate housing.......both top screws were broke off.....I removed housing.....weather stripping inside of housing area was worn away above where screws were
I put a nice thick layer of clear waterproof dealer around hatch area inside where housing goes....put extra on worn spots.....tried to rig screws back on aswell with crazy glue, worked like a charm actually.....put housing back on......them inside hatch area with panel still off, put another thick coat of sealer inside where housing is....just pretty much filled in gap around it....put everything back together
Since then....2 rain storms, decent downpours.....rug was dry both times......still some moisture around hatch lock area, but aslong as rug stays dry, I'm happy
Good luck to anyone....and any questions just ask
Old 05-27-2017, 08:56 PM
kazek's Avatar
hi.i had same issue with flooding trunk compartment.solution I found through pulling plastic cover on the bottom panel.under that panel just by lock pin are drain holes that are........TAPED over with round tape.during the rain water has no drainage and overflows into trunk area.after I peeled tapes off,trunk stays dry.i think ford wanted our vans to rust quickly to make more money on new cars.hth
Joe Reeves
12-13-2013 11:43 AM
rnpalmer2435
06-14-2007 12:48 PM
dmoe
04-26-2007 09:51 PM
sandman
05-13-2005 01:00 AM
Quick Reply: Water leaking in hatch area
