Ford Freestyle The new crossover, combining the versatility of an SUV with the compact size and feel of a station wagon.
Fuel pump wiring
Old 06-22-2014, 04:00 PM
Clgrein's Avatar
Default Fuel pump wiring
Hi all. Not-so-proud owner of a 2007 Freestyle here. I'm trying to troubleshoot a fuel supply issue. I was lucky enough to find the access panels to the fuel pumps so I didn't have to drop the tank. There are 4 wires going to each pump. I'm trying to determine if I have power to the pumps but not sure which wire is which. Can anyone help me out? Thank you
Old 06-22-2014, 04:59 PM
There are 2 things you might try, the first is the owner's manual. It will tell you which fuses supply power to the fuel pump, (s)?
The second path you might try is locate the inertia switch and tap into the wires there and observe if you have power there when you first turn the key on (for 2 seconds) and also when cranking the engine. You need to be careful because there is a fuel pump module in the rear of the vehicle that sends power to the fuel pump when directed by the PCM (computer) and the absence of power directly at the fuel pump could be because of the fuel pump module.
It is a common problem to have a poor ground connection for the pump and many pumps are replaced when not really necessary.
jozepy24
07-13-2019 05:21 AM
fordexpedition2006
04-21-2017 05:23 PM
Spaznaut
05-24-2014 02:10 PM
Rangerj
12-14-2008 01:12 PM
grumpydave
01-18-2008 03:15 PM
Quick Reply: Fuel pump wiring
