Ford Freestyle The new crossover, combining the versatility of an SUV with the compact size and feel of a station wagon.
Loose keyblade on Taurus X IKT remote/key
Old 11-24-2013, 09:32 PM
bighank's Avatar
Default Loose keyblade on Taurus X IKT remote/key
Loose keyblade on Taurus X remote/key The keyblade (metal) in the plastic remote/transponder key has become loose. It twisted as the steering wheel was torque locked. I to start the car and get home. Opened the cover and used a visegrip to reseat the keyblade to the straight position. The remote/transponder portion was loose at the top end where the blade exits but seems to be glued into the plastic housing. Did not try to pry it out as I didn't want to wreck the key altogether.
Can I pry out the remote/transponder packaged in the plastic that is partially unattached in my key? Can I then successfully reattach or make the keyblade solid with epoxy or other means?
See aftermarket remote/transponder SHELLS which contain a keyblade but not the remote or transponder chips. If I get one of these how do I successfully transfer the remote/transponder electronics from my existing key?
bighank
11-23-2013 11:04 AM
rebar
05-12-2013 04:11 PM
NYCArmyWife
11-16-2008 12:29 PM
uofl
05-12-2007 02:52 PM
msgntsu
01-15-2006 10:28 AM
Quick Reply: Loose keyblade on Taurus X IKT remote/key
