Ford Freestyle The new crossover, combining the versatility of an SUV with the compact size and feel of a station wagon.
Check Charging System
Old 08-13-2009, 08:08 AM
rimo's Avatar
Default Check Charging System
I have a 2005 Freestyle that is giving me this message. The battery has 12.5Volts with the engine off. With the engine (and alternator) running it is at 14.5Volts. If I turn everything on in the car, the voltage drops to 13.6 and stays there. When I shut everythin off, it goes right back to 14.5Volts. Someone at work thought the battery voltage was low, so I out a charger on it. When it charged to 100% the battery was up to 12.7Volts but made no difference with the message. I also borrowed a code reader from a friend but it did not find anything either.
Other than the message comming on, the car seems to be running without issue. I took the car to a local mechanic, before I started checking voltages, and they said it was a bad alternator and it would be $400+ for a new one plus $200+ for labor but would not be able to do the job?!?!
I am not sure at this point if in fact it is an alternator issue or some other glitch in the system. I kinda got the feeling from the mechanic that he just didnt want to do the job.
Can anyone help point me in the right direction on this? I want to get this fixed without spending a ton of money swapping parts, I also do not want to be stranded anywhere either.
Thanks in advance for any help.
Dave
mkburak
07-28-2015 08:31 PM
murrays
12-21-2011 07:46 PM
Bonnieangel73
06-06-2011 09:04 AM
Eaton01
08-09-2010 06:25 PM
monie_love06
01-22-2009 11:04 AM
Quick Reply: Check Charging System
