Window issues
Window issues
I have problems getting the back windows to roll down using the driver controls, but the back controls work fine. Does anyone know what the problem could be? The front windows roll down fine using the driver controls.
Hi buddy, I hope that you're doing well.
Most likely the problem is the switch. ... You can also unplug the switch and supply 12V+ and ground directly to the motors leads to roll the windows up or down. If the windows move in one direction the problem is not the motors it is the wiring or lack of ground or power because of the switch.
oedro2021
03-31-2021 04:58 AM
