Door replacement
Old 12-05-2015, 09:41 AM
Diana Alicea's Avatar
Question Door replacement
Can I replace a door without side molding with a door that has side molding?
thank you.
Old 12-05-2015, 11:23 AM
You didn't say what year the vehicle was, since some older vehicles had retaining clips to hold moldings while most later years just used an adhesive that can be softened and removed. If everything else is the same you can remove the stick on moldings to match the rest of the vehicle.
Old 12-05-2015, 12:01 PM
Default Hi and thanks
It is a 2010 Ford Fusion SEL
Old 12-05-2015, 12:10 PM
Default More info
Hi again it is also a 4 door. We want to replace front passenger door. The door we found says in the description "w/ side molding holes". Our original door does not have any side molding...
Since its the exact same color as our car we would really like to get it but want to make sure its the same fit. We figured we could just add the side molding? What do you think?
Thanks so much !!!
Old 12-05-2015, 01:03 PM
If possible speak with someone at the place where you plan to purchase and make sure there are no holes for the side moulding because they are not required.
makuloco2000
12-13-2014 08:41 AM
fl_hayseed
09-26-2010 07:00 PM
pedcrash
03-20-2010 12:42 PM
DWMiller1951
05-11-2006 02:20 AM
Quick Reply: Door replacement
