help! battery replaced wrench light on
Old 10-21-2014, 09:20 AM
tnray's Avatar
Default help! battery replaced wrench light on
hello I just replaced my battery in an 08 fusion now the wrench light is on and the owner manual says throttle/transmission problem? I have no throttle response. I am confused
Old 10-21-2014, 01:44 PM
Something you can try.
Remove the negative battery from the battery and connect it or hold it on the positive battery cable still on the battery for a few minutes. When done reconnect the negative cable to the battery and see what you get. This allows any glitches in the computer to drain down and is referred to as a forced/soft reset. Many times it will allow a fresh start for all/most systems.
Old 10-22-2014, 12:50 PM
tnray's Avatar
Default Thanks
Did that. I have never seen so much trouble out of just replacing a battery omg.
guthrie1013@gmail.com
06-25-2020 11:45 AM
flamingitaur
01-13-2011 02:32 PM
pstrjeff
04-17-2008 10:35 AM
MarlboromanI
11-30-2006 10:28 AM
Quick Reply: help! battery replaced wrench light on
