Just a few question's about my 2010 Fusion.
Old 12-14-2013, 05:05 PM
chadw00's Avatar
Default Just a few question's about my 2010 Fusion.
Hi everyone, I just have a couple questions about my 2010 Fusion SEL V6.
1. Where can I hookup a tow strap or chain? To pull out of a ditch for example.
2. When I shift into drive or reverse there is a 2-3 sec delay before it engages. Is this normal? If not what can I do to fix it?
Thank you.
Chad
Old 12-15-2013, 07:24 AM
tempforce's Avatar
use the factory hold down loops on the body/frame. they were installed to hold the vehicle during transport... the next option is a reinforced part of the frame or wheel assembly. don't grip/hook onto anything that is part of the steering or suspension support assembly. unless it is part of a frame or sub frame... damage will result costing lots of $$$$$..
check your trans fluid level for the slow shift.. if o.k. then you have a poor seal in the torque converter, low pressure to the bands/clutches. get it fixed before the repairs become more expensive...$$$$$
Old 12-16-2013, 06:31 PM
chadw00's Avatar
Thanks for the info. I will definitely check that out. Do you know approximately where the tie down hooks are? Thanks again.
Chad
LakeSuperiorFordDriver
Mid West
12-12-2012 10:13 AM
aziljesani
01-28-2011 01:07 PM
kpothast
12-08-2010 10:05 PM
DonnyB1
03-21-2010 12:16 AM
Quick Reply: Just a few question's about my 2010 Fusion.
