2003 Mustang 3.4L No start
Old 12-15-2015, 09:25 PM
macamon's Avatar
Default 2003 Mustang 3.4L No start
My girlfriend's car refused to start today. Mostly just turning over, once it tried to run and stalled. When I got there I checked the CPS and it was clean. Checked all connections. After another failed attempt to start, for giggles I toggled the ignition switch 10X and it started.
After about 10 seconds it stalled, but started right back up again and was able to drive it home. I checked with a code reader, ran KOEO AND KOER diagnostics and there are no codes.
Due to the fact it started after the ignition switch rotations I suspect ignition switch but typically if you wiggle the ignition switch while running it will stop running at some point.
Thanks in advance for your assistance
Cygnus
Old 12-18-2015, 12:29 PM
How did you make out with this? Appeared you were on top of the cause.
The Hef
08-04-2014 08:37 AM
ENFORCER
11-12-2010 04:20 PM
Jerry Pucciarelli
02-05-2009 12:19 PM
Goatfarmer
02-01-2008 11:34 AM
hphillips92006
08-25-2006 11:50 PM
Quick Reply: 2003 Mustang 3.4L No start
