01 ranger skipping
Old 02-05-2009, 11:51 AM
dustymedic13's Avatar
Default 01 ranger skipping
I have a 01 ranger 2wd with a 3.0 v6. The check engine light came on and the code says it is misfiring on #4. I have replaced the plugs and wires and cleared the codes. light is back on with the same code. Help! Where should I go next! Thanks!
Old 02-06-2009, 07:38 PM
Use Common Sense's Avatar
I would check to make sure that the coil pack has a good grounding surface. If it's good, then you may have a bad coil pack.
coil pack is $72 at www.rockauto.com
'99 Vicky
01-27-2010 05:59 PM
ylekiotez
03-11-2009 06:55 PM
cobrasnake81
11-13-2008 05:12 PM
disk11
08-16-2008 09:13 PM
jimw
11-20-2007 06:38 AM
Quick Reply: 01 ranger skipping
