1994 ford ranger 3.0 won't start
Old 03-03-2015, 06:30 PM
grahambo13's Avatar
Default 1994 ford ranger 3.0 won't start
Previous owner replaced head gaskets hasn't started since I have done a full tune up and won't start unless I set The timing 10 degrees before tdc the will start but runs rough and dies
Old 03-04-2015, 01:42 PM
I'm having a little trouble understanding your post.
Are you saying it has not started since the head gaskets were done or since you did the "tuneup" ?
Old 03-04-2015, 04:01 PM
grahambo13's Avatar
It has not started since the head gaskets were dome
Old 03-04-2015, 08:32 PM
There is a very good possibility the distributor was installed incorrectly.
There are a few videos on u tube that explain the proper procedure to do this.
Old 03-04-2015, 09:10 PM
grahambo13's Avatar
How could it be installed incorrectly the front is in time and put the rotor button in time with the #1plug wire at top dead center it won't start
Old 03-05-2015, 05:27 AM
Use Common Sense's Avatar
Just throwing a little help you way. You probably already know some or all of these.
1. With no advance, the timing should be 10° BTDC.
2. Firing order is 1-4-2-5-3-6 (Clockwise)
3. #1 at TDC "Ready-to-Fire" is at the 10-11 O'clock position
4. Passenger side front to rear = Cylinder 1-2-3
5. Driver side front to rear = Cylinder 4-5-6
6. Are you using the pre-existing ignition parts? (cap, rotor, plugs, wires) If so, I would use new. A simple cracked cap can cause erratic/no firing issues.
Old 03-05-2015, 05:40 AM
Use Common Sense provided some important info. One of the things you need to do now is to confirm the ignition system is set up according to that info.
Old 03-05-2015, 08:20 AM
grahambo13's Avatar
How do I confirm that ignition is set up for that. It has all new parts and I already did what common sense said
Old 03-05-2015, 07:02 PM
Did you confirm that the spark plug wires go in the correct direction from the correct starting point and in the firing order he provided?
Old 03-05-2015, 08:27 PM
grahambo13's Avatar
Yes I went by the book it said the same as he did
Quick Reply: 1994 ford ranger 3.0 won't start
