98 Ford Ranger 3.0 Liter Misfire
Old 09-03-2012, 02:07 PM
Jpope85's Avatar
Default 98 Ford Ranger 3.0 Liter Misfire
Got in my ranger the other day and noticed lack of engine power, as well as rough idle. Check engine light came on. Autozone diagnosed from the computer as cyclinder 3 misfire. I replaced all the spark plugs, cylinder 3's plug was pretty nasty looking, all others were fine. This didn't fix it. Next I replaced the ignition wire from the coil pack to the plug and that fixed it, for a few hours, then back to square one. Should I just keep moving up and replace the coil pack at this point? Thanks.
Old 01-27-2017, 04:28 PM
brianc's Avatar
Default 98 cylinder 3 misfire
Jpope85 did you ever find the problem with cylinder 3?
Old 01-28-2017, 10:19 AM
Jpope85's Avatar
Yes! It was a bad coil pack, ended up replacing all the plugs, wires, and coil pack.
Jpope85
09-03-2012 01:43 PM
badnews
10-03-2007 10:05 PM
tomb1269
09-19-2007 12:31 PM
MudWarrior
03-05-2006 03:52 PM
Quick Reply: 98 Ford Ranger 3.0 Liter Misfire
