Fuse Problem
Old 02-26-2008, 10:44 AM
awoods1454's Avatar
Default Fuse Problem
I have a 2003 Ford Ranger Edge and am having problems with the fuse box. A few days ago my truck wouldn't go into gear with the motor running. If it is in accessory mode it would. So I took out a fuse (I can't remember which one right now) but then it would work. I know if you take the fuse out for the alternator, it will work, but I can't drive without the alternator. Has anyone had this problem?
Old 02-27-2008, 12:53 PM
tomb1269's Avatar
Default RE: Fuse Problem
check your fuse again, there is a fuse that controls the park lock safety switch and when it blows you can not get it in gear.
Old 02-27-2008, 01:43 PM
awoods1454's Avatar
The fuse did blow, but it keeps blowing, it's supposed to be a 7.5, but I put a 10 in there and it hasn't blown it yet. Is this ok?
Old 03-06-2008, 03:44 PM
tomb1269's Avatar
To get by, but you want to check it out and find the intermittent short.
t72384tom
09-16-2009 07:36 PM
t72384tom
09-16-2009 06:11 PM
tigerfan
09-25-2008 11:45 AM
fw31100
09-21-2008 08:13 PM
rhokett
11-29-2007 05:19 PM
Quick Reply: Fuse Problem
