2002 Ranger, The ABS light stays on, AIRBAG light flashes, The Speedometer quit all at the exact same time. Is this a fuse problem.? Or each one a problem in itself.?
Are there any other lights that come on? Try messing with the ignition switch (rattle the key around in the run position) when the truck is running and sitting still. Could be a worn out ignition switch.
