trans light flashing
Old 08-05-2007, 08:47 PM
rangerII's Avatar
Default trans light flashing
I can't figure it out. The trans in my 2003 4x2 ranger will go into "safe mode", I guess,usually when I first leave my house. It happened more frequently during the colder weather, but will do it once in awhile still. I usually can fix this by restarting the engine and it won't act up for the rest of the day. The truck has a 2.3L with 24K on it as well as the tranny. I did a motor/ tranny swap into a higher milage truck,123k, from a wrecked, salvage truck. One thing bothers me real bad, it seems to wind too long after you pass another car and when the engine rpm's come down it will upshift. I don't think it should do this. I have changed the fluid and filter to no avail.Also, it seems to go into gear with some hesitation hot or cold. It has remained in 2nd at a stop light 2 times which I'm uncomfortable with. It always seems mushy shifting.I really need some input to correct this,
Thanks to all
Old 08-20-2007, 12:46 PM
tomb1269's Avatar
Default RE: trans light flashing
When you did the swap into the truck did you take the computer?
Old 09-04-2007, 09:06 PM
rangerII's Avatar
I tried to use the computer from the salvage truck but the coded ignition key would not sync with it. You are referring to the computer in the cowl correct. I had the codes removed once before.The only thing it did however is kick the theft light on in the dash.
Old 09-05-2007, 01:32 PM
tomb1269's Avatar
There are some sensors that may be prt of the problem that only thenewer computer will deal with. I think one is the VSS. I am not quite sure what it does.
tomcat5
08-10-2021 05:10 PM
italianjeremy
03-03-2006 10:59 PM
Cactus
05-24-2005 12:59 PM
ajrn
04-12-2005 05:16 AM
Quick Reply: trans light flashing
