Heater/AC blower intermittant - 1996 F150, 4.6 4WD
Old 07-29-2016, 06:59 PM
sourdough doug's Avatar
Default Heater/AC blower intermittant - 1996 F150, 4.6 4WD
the heater AC/blower works now and then. I noticed that when it stops, if I back off the accelerator, it kicks in...I suspect some kind of vacuum leak. At the same time, today, I also notices a stumble/hesitation when accelerating in neutral....could they be related ?
Old 08-27-2016, 11:17 AM
Kristopher Day's Avatar
did you find an answer to this anywhere else. I am having same problem
Old 08-27-2016, 04:19 PM
Hi Guys,
I thought I answered a post similar to these a few days ago, but in any case you should be looking for a good sized vacuum leak. The reasoning behind this is; with the throttle butterfly near closed position maximum vacuum is available to the reservoir and accessories. When the throttle is opened vacuum drops and the reservoir is supposed to provide momentary vacuum to the accessories and the drop is not noticed. If the leak is large enough which in this case it is, you are noticing the result of insufficient vacuum. Leaks could be cracked vacuum hose somewhere, hose came off, or possibly a cracked vacuum reservoir which has become quite common these days. I would suggest starting with the previous suggestions and you might get lucky and find it right away. You could try pinching different vacuum hoses and look for an immediate but quick duration change in engine idle speed.
Sometimes you can use a plastic bottle with a small hole in the cap and squirt water around the areas you suspect and you should notice a definite difference in idle speed even for a second or two.
BigGreenVan
05-31-2012 03:02 PM
otsdad
11-27-2010 02:44 AM
hilliad
07-04-2010 02:26 PM
Evomaniac87
03-19-2006 08:32 PM
Deam
08-01-2004 06:20 PM
Quick Reply: Heater/AC blower intermittant - 1996 F150, 4.6 4WD
