ignition knock sensor
hello again everyone,
got my info I needed to get my vacuum lines hooked up, next question I have is, where does the ignition knock sensor go? I hope not to far down, it was sitting on the work bench, and not with the other parts, I know I need it because the is a connector wire for it, would appreciate any help, learned a big lesson on this one, I tore it apart about a month and a half ago, things happened, didn't get to fix it right away, should have taken more pictures and label everything that you can, lesson learned, thanks
bobcity
02-28-2013 12:24 AM
