ACCESSORY SHAFT PULLEY
Old 11-23-2008, 10:13 PM
5thwheel's Avatar
Default ACCESSORY SHAFT PULLEY
[&:]Howdy , I did a change of the timing belt before the thing would break and waist the valves .But the accessory dirve pulley got turned ,?how do I know where to time it and what dose it DRIVE????
Old 11-24-2008, 05:46 AM
5thwheel's Avatar
Default RE: ACCESSORY SHAFT PULLEY
vehical :1997 ranger :
Engine ; 2.3 [EFI]
; 2 WD
; no air
; standerd 5 speed
Also changed the air fillter,water pump and its belt along with thermostate w/ a new houseing
Old 11-24-2008, 11:52 AM
Oil pump/CMP
Here's the belt timing diagram.. If you need the instruction let me know..
[IMG]local://upfiles/6756/CDC32617AED548C2A52E385B63A10D65.gif[/IMG]
Old 11-24-2008, 11:22 PM
5thwheel's Avatar
TKX,S FOR THEPIX & TKX FOR THE REPLY ,,, HAY;; WAY COOL PIX W/PILOT MASK ON THE BIKE TOOO THUMBS UP-UP AND AWAY.....
PS; WOULD THE ACC. DRIVE BEEING OFF TIME MAKE THE ENGINE RUN ROUGH ? OR MAYBE IT'S JUST THE MANY PIN HOLLS IN THE MUFFLE
Old 11-25-2008, 11:40 AM
Yes,,
If the CMP (cam position) sensor is out of time it will cause a poor running condition since it provides a cylinder identification signal forfuel injection. It's triggered by a raised area on the back of the oil pump drive sprocket so correct timing/location is important.The 'diamond' timing marks are on the inner timing cover and on the pump sprocket at the 12:00 position when aligned.. The CMP is behind the A/C P/Smounting bracket..
Amos Harper
11-10-2010 08:53 PM
Conundrum
02-07-2007 07:48 PM
live4perfection
10-09-2006 12:54 PM
live4perfection
10-09-2006 01:54 AM
Conundrum
02-15-2006 05:01 PM
Quick Reply: ACCESSORY SHAFT PULLEY
