Ranger 2001 - Brake Pandal has NO pressure
Old 08-15-2010, 02:27 PM
CoolRanger's Avatar
Default Ranger 2001 - Brake Pandal has NO pressure
Greetings all,
1st of all, I'm not too sure if this is the right formrum/section to post my problem. If it's not, my apologies are on the way.
Anyways, I just become a Ford Ranger 2001 owner for a month. I recently have a problem with the brake padal; I can push it on the way to the floor, but no pressure of any kind. Checked all the master/slave cylinders and rear brakes - left and right. No sign of leaking at all. Can anybody shade the light on my way as I'm trying to fix it myself (since I have no $$$ to take her to the local stealership).?
Thanks in advance for your responses!
Regards,
Rangerman
Old 08-16-2010, 11:32 AM
stuart40ca's Avatar
Is there any fluid in the MC?
Old 09-08-2010, 06:36 PM
If you decide to change the master cylinder make sure you check for the proper procedure for bench bleeding and brake system bleeding. Many times the procedure comes with the new/rebuilt cylinder, but it's very important to do it properly. Your life and others may depend on whether the job was done correctly. If not sure , just ask ,thats why we are here
Eligee1
01-10-2012 09:04 PM
furious1247
01-07-2009 06:06 AM
cscottyn.1
10-31-2006 05:47 AM
jtanker1775
02-25-2006 08:38 PM
blublu
12-02-2005 05:22 PM
Quick Reply: Ranger 2001 - Brake Pandal has NO pressure
