2001 ST starts, dies, then doesn't start
I have been having issues with my 2001 sport trac 4x4 v6 sohc fuel inj. 132k mileage. The problem is I can jump in and it will start first try, fuel pump is heard activating, idle is rough, feels like truck is about to die, pumping on the gas usually causes it to catch and smooth out......after 10 mins. or sometimes less than that truck starts to sputter, step on throttle it dies faster, sometimes when stepping on throttle before it dies helps and truck is able to rev up and then back to idle and not die. But most times stepping on gas when it begins to sputter after running for 10 mins or so causes it to die once it dies it doesn't start back up and when key is turned on and off, no fuel pump activation noise.
I have scantool data take off a autel 619 saved to notebook text format. But have no idea how to post it here or if it is allowed.
Those are my numbers for the scan tool, sorry so long, suggestions I have gotten so far are vacuum leak, failing fuel pump, bad o2 sensors, bad MAF.......so far replaced fuel filter and cleaned MAF.....it made no difference....any info regarding data from scan tool and where to start would be greatly appreciated, thank you and have a blessed day.
