2003 ford sports trac, turns over but won't start sometimes.
Hi! common sense, the outside temp, is hot, it is like I have to let it cool down for it to start again. Tried to connect it to the obd2 meter and nothing shows up, no code nothing, but when it starts it will keep starting untill one day it does it again does not start. Tried to check the fuses all is fine, relays all is fine change fuel filter,reset the button on the passenger side still won't start, altough sometimes I don't hear the fuel pump run for before it start or do you have to hear the fuel pump start every time you start the car. I think if your fuel lines are primed you won't hear the fuel pump run all the time. I am almost out of patience with this problem for it happens everywhere and anytime without any warnning.Thank for your reply hope I can pickup alot from it to fix it, thanks again so much.
