Ford Sport Trac SUV seating and versatility meets the compact pickup truck in this crossover.
2004 sport trac flasher fuse/relay location
Old 06-10-2008, 12:21 AM
Freewalker's Avatar
Default 2004 sport trac flasher fuse/relay location
My turn signals just stoped working today, All lights still work but the turn signal wont come on. Could anyone tell me the location of the flasher fuse/relay? Thank you
Old 06-10-2008, 12:30 AM
Default RE: 2004 sport trac flasher fuse/relay location
Fuses are location (F2.15) 7.5amp in the Central Junction box (CJB) and F1.34 15amp in the Battery Junction Box (BJB)... Indicator relay is the in the AUX Relay box 2 under/behind the instrument panel.. Could be the multi function switch as well.. Do the hazard flasher operate?
Old 06-13-2008, 11:11 AM
Freewalker's Avatar
No the flashers dont work, I found the flasher relay box and replaced the big flasher relay but it still didnt help. I was feeling around on the other Black fuses and the last 2 fuses were hot, could that have something to do with it? there was a blown fuse in the fuse box in the cab of the cat but I didnt check the battery junction box yet. Thank you for your time and help.
Old 06-13-2008, 03:40 PM
Freewalker's Avatar
hey thanks for the help i found the fuses and they were burnt out replace the fuses and everything is working, Once again thank you for your time and help
Old 06-13-2008, 04:08 PM
Glad it was a simple fix....
Old 05-19-2012, 09:58 AM
mike_gear's Avatar
after opening both fuse panels on my sport trac neither are marked as to which fuse is for which function. I'm haveing a problem with the cruse control and want to check the fuse. Which one is for the cruse??
Towguy76
05-22-2013 12:01 PM
Drag Racer's Daughter
05-15-2012 06:14 PM
troyhay
11-04-2010 04:47 AM
Kav
08-19-2009 07:02 PM
twalters71
03-23-2009 12:50 PM
Quick Reply: 2004 sport trac flasher fuse/relay location
