2000 3.0 misfire @ idle
Old 03-02-2006, 12:42 PM
ll356's Avatar
Default 2000 3.0 misfire @ idle
My wifes 00 Taurus 3.0 with 125K has developed an engine miss at idle only. Scanner says cylinder 1 misfire & cylinder 2 misfire. Plugs & wires were replaced & codes cleared & ran fine for a day & then started same miss at idle again with the same codes. New injectors were installed & codes cleared & again same problem. Tried used coil pack & same problem. Ford garage says it might be computor but even if it isnt I would still have to pay for the NEW computor. It runs fine off idle & I would just live with it but in New York state it will not pass annual inspection with codes stored. Any help out there would be greatly appreciated.
Old 03-18-2006, 11:03 AM
Default RE: 2000 3.0 misfire @ idle
I had the same problem. Thought it was going to be bad, $$$ but it ended up being a broken hose at the PVC valve. The hose is a formed part. it split at the elbow that attaches to the PVC.
I cut the hose and used a new PVC valve that had an elbow built onto it. That way the hose can stay straight. Cant remember the Part #.
If you hear an air sucking noise with the hood open, you may have the same problem.
mardyel
12-14-2016 11:21 AM
Sandman400
03-30-2013 12:46 PM
qwikrnu
12-03-2012 02:45 PM
jeremychips
04-05-2012 06:41 PM
miknwv
09-03-2006 04:16 AM
Quick Reply: 2000 3.0 misfire @ idle
