99 taurus duratec oil leak
Has anyone had any experience with oil leaks on the 3.0 duratec engines? I have a 99 with 110,000 miles on it that has an oil leak appearing to come from around the oil pan. I was wondering in anyone else has had this problem or any other oil leak that could explain oil in this area.
oil leak
I need to look again to be more certain but it does appear to be coming from the gasket and it it definitely coming down the side of the oil pan with drops hanging from the pan. Have you had experience with leaks further up the engine?
oil leak
Yeah, I hope it does'nt get that bad. I'll keep a close eye on the oil level and probably do it at the next oil change. Any tips on breaking the exhaust bolts loose? I'll probably try to soak them in some penetrating oil a few times and see if I can get the bolts to break loose before I try it. Is there any way around dropping the Y pipe? In the pictures I saw it looked like an oil pickup hung way down in the pan and would make it hard to manuveur the pan around the Y pipe.
murrayatuptown
01-05-2013 12:49 PM
twigfarm
01-15-2012 09:20 PM
