Erratic fuel pressure on 2002 Taurus - Ford Forum - Enthusiast Forums for Ford Owners
Thread Tools Search this Thread
Old 04-29-2012, 05:35 PM
Default Erratic fuel pressure on 2002 Taurus
I have a 2002 Taurus and my fuel pressure varies. Some days it runs and accelerates great. When I check the fuel pressure it is between 50-55 psi. Sometimes when it bucks on acceleration I go home and check the fuel pressure and it reads from 24-40 psi. This happens quite often.
I would think it is the fuel pump but I don't want to replace it if it is not the problem. I also suspect a bad fuel pressure regualator but it is not on the fuel rail as in previous years. Is the regulator built into the fuel pump. When I look up the regulator on Autozone's webpage it does not show one for my car. Any help would be greatly appreciated. Thanks
Old 04-29-2012, 07:33 PM
Don't know just how much help this will provide, but may clear up something.
I believe The fuel system on your vehicle has what is referred to as a returnless fuel system. That means there is no return line coming from a fuel pressure regulator that used to be located in the engine compartment. The pressure regulator is now part of the fuel pump module in the fuel tank. The fuel pump is controlled by a pulsewidth modulated system where the fuel pump runs only when necessary and can have different pressures as long as the engine is supplied with the amount of fuel actually needed.
There is still a filter in the line and do you know if that has been changed recently? It might help if you had Autozone check for any codes in the computer. It might provide some direction.
There should be a fuel pressure sensor on the fuel rail that is supposed to tell the system if more pressure is needed.
Thread Thread Starter Forum Replies Last Post
2002 Escape V6 erratic/fast idle billburn New Member Area 0 05-25-2014 07:05 PM
Help! Erratic Fuel Gauge in '91 Escort barariel Ford Escort 2 06-05-2011 06:54 AM
99 Expedition with erratic fuel gauge. mecurtiss Ford Expedition 0 09-01-2009 03:53 PM
Erratic fuel guage on 91 Aerostar TAZ454 General Tech 1 12-04-2008 09:03 PM
Service Bullutin on 87-88 Fords with erratic fuel guage mkfarnam Ford F-150 0 04-12-2007 03:07 AM
Tags
02, 2002, 33, code, codes, compartment, engine, eratic, ford, fuel, photos, pressure, regulator, tauraus, taurus
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
