No Heat! Coolant flush procedure
Old 10-28-2013, 06:31 PM
makuloco2000's Avatar
Default No Heat! Coolant flush procedure
Had my first one of the season with the usual not enough heat from the vents. While the heater core replacement is recommended too. Depending upon the severity, this coolant flush procedure may also do the trick. Either way it's the first step to replacing the heater core so might as well try it and see. I decided to make a video of the the procedure we use at my shop that is tried and true. Hope this helps!
Old 12-15-2013, 11:55 AM
Hope this has helped some!
Use Common Sense
06-25-2016 01:30 PM
Eligee1
01-19-2012 11:09 PM
BUSTYSIN
12-15-2006 09:01 PM
butters417
03-22-2005 02:21 PM
butters417
03-20-2005 10:38 PM
Quick Reply: No Heat! Coolant flush procedure
